1.6 EZ Head Gasket Change
Discussion in '8-valve' started by Richjay77, Jun 26, 2010.
  1. rubjonny
    yep, if you can ;)
  2. Richjay77
    Richjay77 Forum Member
    The engine is out, but guessing via your msg its a ball ache even then?
  3. rubjonny
    can be yes, inlet is usually no bother but exhaust nuts like to seize on. you might be alight though, the only engine ive really struggled with was my old 1.6 driver. this was because the coolant channel oring had been leaking for years so the 2 exhaust nuts below it had corroded into solid lumps of metal which required 1 to be cut off and drilled out.
    thought with the engien out at least you have loads of room to work! the head bolts are a struggle with engine in as they're tucked right in there, but with it out its much easier to see.
  4. Mike_H Forum Addict
    Should be a lot easier to get the manifolds off with the engine out. At least you can get in at the exhaust nuts with a grinder / chisel, and you can see what you're doing on the inlet, rather than feeling your way.
  5. Richjay77
    Mines a 1.6 driver John lol may have some fun if mine has gone the same way lol
