We are pleased to be able to supply in association with wossner 1.8t to 2.0 stroker forged pistons. These are wossner forged pistons for the 1.8t engine when using a 2.0 crankshaft.
Intergrated engineering do a kit. Uses a 2.0L TFSI crank, IE rods and JE pistons. Thats what i'm having in mine!
Price for the pistons will be 500 inc vat and are readilly available in 82.5 and 83mm bore sizes. you can use any 2.0 crank mk3 2.0 8v mk3 2.016v aslong as they have a trigger wheel for your crank sensor. We also do our own con rod sets these are 450. We could supply a crank also if required.
The only thing you need to do is get the nose of the crank modified if using a mk3 2.0 crank to run the oil pump.
2.0 20v t stroker kit TSR have now taken stock for our 1.8 to 2.0 20vt stroker kits they include Wossner forged pistons TSR H beam con rods inc ARP bolts 2.0 fsi crank modified to run 20v oil pump. costs are 1200 inc vat These are in stock and available immediately. We are currently building 2 customers cars with these kits and enquiries for fully built engine prices are welcome.
glad i found this now ! are the pistons available in 83 mm still and can tell me how strong the conrods are or how much hp/torque they can handle?
The pistons come in 82.5mm or 82.7mm. The con rods will cope with 750bhp but over 500bhp ARP L19 bolts should be used as opposed to ARP2000.
