Hello, I have one question. I have golf mk2 and I have chance get Seat leon Cupra R engine. Engine code is BAM. I all time search Audi TT 1.8t 225 BAM donor in my golf mk2. It is same engine and pats? I plan to use in my golf mk2. Thanks.
today was look donor in real. All is good, but I see, that engine mount is on body, looks like this: https://drive.google.com/file/d/0Bydxj3qYez_8enBVVzBOeHF6MG5kTGtfOW5xdXctU0ZURXpV/view?usp=sharing I have a question, I can turn away this engine mont and use original engine mount on mk3 travers? Thanks.
You want one of these http://www.dutchbuild.com/index.php/shop/db-customs/gearbox-and-engine-mounts/02m-gearbox-mount-detail
First sorry for my bad English. short: Original this engine moun look like this: https://drive.google.com/file/d/0Bydxj3qYez_8enBVVzBOeHF6MG5kTGtfOW5xdXctU0ZURXpV/view http://s1165.photobucket.com/user/vw4lbb/media/caddymount4.jpg.html I do not want to use this engine mount, because me need to modify golf body, I want use this engine mount on this BAM engine: http://i697.photobucket.com/albums/vv335/koala_bear83/MK3rightRearEngineMount.jpg http://www.aniiaaa.webspace.virginmedia.com/vw/mount4.jpg Is can use this, or no? Thanks.
ah i see you need a mk2 golf 16v rear engine mount like this http://www.ebay.co.uk/itm/VW-CORRADO-GOLF-JETTA-MK2-1-8-16V-KR-REAR-ENGINE-BRACKET-MOUNT-SUPPORT-G60-/331725075092?hash=item4d3c5af294:g:4X8AAOSwfZ1WYi8t the last picture is a front mount witch is no good for the rear
The 16v mount has 3 bolts and is different to this http://i697.photobucket.com/albums/vv335/koala_bear83/MK3rightRearEngineMount.jpg This is a later mount http://www.ebay.co.uk/itm/Variant1-Febi-Rear-Right-Offside-O-S-RH-Engine-Mount-Genuine-OE-Quality-Part-/391004194472?fits=Model%3AGolf%7CPlat_Gen%3AMK+II&hash=item5b09aa86a8:g:C~MAAOSwD0lUf9xM This is the early style mount http://www.ebay.co.uk/itm/VW-GOLF-MK2-GTI-JETTA-ENGINE-MOUNT-REAR-O-E-NEW-191-199-262-A-191199262A-/181928348416?hash=item2a5bc64b00:g:JXIAAOSw-dBTuuOw
I use golf mk3 vr6 subframe, this is my: https://drive.google.com/file/d/0Bydxj3qYez_8VGpTS0N3aDU1M3M/view?usp=sharing So rear Engine mount I must use from 16v or corrado, yes? How with front engine mount? Whats mount me need?
with a mk3 subframe you need MK3 or SEAT ABF or TDI rear bracket for the front bracket this needs to be golf G60, 4 cylinder corrado or most passat b3/4 regardless of what subframe you have. unless you fit a corrado vr6 or higher spec passat/toledo front engine carrier which takes a mk3 golf mount, in that case you need SEAT/MK3 abf or TDI front bracket
Finally ! Thanks so much ! Who with gearbox mount? I read, than some people use from corrado gearbox mount..
any 02a gearbox mount will do 4 or 6 cylinder. so all corrado and passat b3/4 manual models, mk3/seat 16v vr6 or tdi, golf g60 etc
