I have a 1999 1.8t passat. engine code aeb would it be possible to fit this engine into a 1991 8v gti. i have looked on quantum's site and they used a different engine code. wot bits can i use from the passat or do i need to source others? can i just drop it in? cheers
1.8t the inlet manifold is different the turbo manifold is different the turbo is different the mk2 mount should fit with some grinding to the master cylinder i used an agu engine what gearbox you going to use?
