Anyone used any of these before and do they work ? Awesome GTI sell them for the 20vt, they also show rolling rd graphs for it. "Gives you more power in your 1.8T by reducing the temperature of the incoming air to your engine with an insulating gasket that radically reduces the heat transfer from the cylinder head to the intake manifold. This gives you cooler, denser air for more horsepower and performance from your engine. Made from a high performance polymer, PowerGasket conducts on average less than 1/500th of the heat of the steel gasket that it replaces. Your intake manifold will stay 30-50 F cooler and your incoming air will stay 20-30 F cooler. Cooler air, denser air, means more oxygen. Your engine sensors register these changes and will inject more fuel to give you more power. Cooler air also reduces detonation, so you can turn up the boost or advance your engine timing for even more performance gains. PowerGasket has been designed for affordability, easy installation and no disruption to your manifold attachment and engine accessories. This means that you can simply swap your old intake manifold gasket for a PowerGasket. No buying longer bolts or installing multiple gaskets. In less than 2 hours, you will be enjoying a more powerful, better performing ride."
there was a group buy for them on here mr.brown I believe sorted them?ive not fitted mine yet but a few others might of and post comments
