Hi all, hope somone can shed some light on this. revs drop when on tickover IE. when approaching junctions,traffic lights etc. sometimes stalls. also needs lots of throttle when pulling away but is fine at other revs/speeds. Suggestions so far are, MAF sensor, fuel filter,temp sensor or air leaks
i would go more for temp gauage, also it is cheap and easy to change, what is your temp reading when it's stalling
as above remove T/body and give it a chemical clean, bet you a jam tart it will be think in oil on the back part of plate I've never came across a temp sensor causing a cutting out fault
