1300 driver playing up
Discussion in '8-valve' started by K13_RAN, Jan 26, 2005.
  1. K13_RAN Forum Member
    the dizzy cap and rotor arm are pretty new, under 2months old, an di
    have put two sets of leads on so far, the last set only about 2 weeks
    ago[:^(]
    What about spark plugs? Might be worth taking all 4 out to check their condition.
    Post a pic up on here :)
  3. K13_RAN Forum Member
    Sure i will do that...but again, ive only very recently changed them
  4. K13_RAN Forum Member
    ok heres a pic of my nearly new plugs[:s]
    just a note i used a little bit of grease on each thread putting them in, but is it me or are they in pretty shocking condition?
    bearing in mind i have been playing around with mixture settings etc so
    i suppose that will explain a little of the carbon on them.....what do
    you reckon about them guys????
    Edited by: K13_RAN
    Thoughts, though I haven't read responses in detail.
    * Check fuel pump cranking fuel through ok
    * Get top off carb - clean inside. Consider whether the float needle valve is sticking
    * Take bolt out of lower right hand side of carb (bolt on outside). Remove main jet my inserting screwdriver through hole into float chamber. Check it's clear.
    * Other thought: are your points in OK condition. They cause h3ll when they play up.
    You are definiely having problems with fuel, not sparks.
  6. greg s Forum Member
    Kieran, I've got a fuel pump which you're welcome to have for the price of
    postage. Failing that I've got an entire carb off a 45k mile car. Just drop
    me a PM.
  7. K13_RAN Forum Member
    chris ive completely stripped the carb and cleaned out all of the jets and float chamber
    ive not checked fuel pump is cranking through properly, how do i go
    about this? although the car will run fine for a few miles before
    it starts playing up
    did you have a look at the spark plugs picture, one of them looks oily,
    do u think maybe i have a headgasket or piston ring problem???
    thank you greg that would be a great help
  8. mk286GTI Forum Member
    could be something really basic, on my old 1600, the flap for the hotaircontrolled by the vacuum had rusted and stuck shut, so never opened. worth a check!
  9. AxlFoley Forum Junkie
    Wales
    try running it without an air filter see what happens
  10. K13_RAN Forum Member
    ive checked the flap is working
    is that a good idea??[:s]
    Are you definitely happy the needle valve is OK??
    Take the feed pipe (from the fuel pump to the carb) off the carb, and put it into a bottle/container. Then crank engine over. If it fills the bottle, then great. Should be ok. Even better if you can try this test immediately after it breaks down - I had a pump that would intermittently fail. The clue is that the pump is leaking (engine) oil from the small hole in the fuel pump casing, indicating that the diaphragn is on the way out.
    Alternative suggestion is that the tank is full of crap and the guage at the bottom of the tank pick up pipe is getting blocked. Get to this under the rear seat. It's a twist-off pain in the neck to get off. Use a hammer onto a long piece of wood and bang anti clockwise by about a quarter of a turn.
    Chris
  12. rubjonny
    Like Chris says test it immediately after the car dies. This is exactly what happened on my dads 1.3 it would just cut out randomly. The AA bloke took the hose off the carb and got me dad to crank it over, got nothing for a few seconds then fuel started coming though. Once he connected it back up the car fired up straight away!
