16685 fault code on my polo
Discussion in 'Vagcom / VCDS' started by nut 20v, Sep 18, 2013.
  1. nut 20v
    nut 20v CGTI Regional Host - Birmingham & Midlands
    Overtaking you
    Hi I have a misfire on my polo vagcom is giving this code 16685 cyl 1 misfire po30135/10 Ross tec wiki is giving multiple solutions has anyone come across this and solved it or knows what it is I'm hoping its a coil pack but I'm not sure cheers in advance
  2. GVK
  3. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    Coil pack likely, next option compression check, or possible injector
    I have seen loads with exhaust valves sticking/no sealing normally related to fuel burning(mainly from the same local supermarket!)
  4. GVK
    I bought one of those coil pack pullers when at VW, haven't used it since!! [8(]lol
  5. nut 20v
    Overtaking you
    Unplugged no 1 coil and it run no different so replaced that and all is fine cheers
