because when I sort out my setup for running E85, I am going to have duel fuel cells - one for regular petrol (99 octane shell optimax) and the other (much smaller, maybe 5L) for 'test fuel'. 'test fuel' is going to be several different things - not just E85 - there's a whole load of interesting fuels out there which I want to examine it would be nice to have the capacity to run 6 different maps with a dash switch to move between them its quite possible that certain fuels will be better for different conditions
tips for using methanol: http://www.ctracing.com/alcohol.htm http://racecarbook.com/5hpInfo.shtml alternative fuel racing: http://www.aeracing.org/ - would be nice to attend this http://www.eemsonline.co.uk/altfuels
I don't know for Motec but for their price they should make even coffees ;p check about them Interesting idea
what about 'fuel' saturated with liquid oxygen......that could be interesting a test for my garden engine
Nobody please do this - LOX is VERY dangerous and only trained scientists should be allowed to play with it in the safety of their garden sheds (incidentally - if you soak a charcoal brickette (barbeque fuel) in LOX and throw it at the wall - it explodes spectacularly.....but again, disclaimer: DO NOT DO THIS )
Hmm better with Nitrous i think that the correct term for it ! ask Phatty he's just discovered its uses p.s. Megasquirt will switch between 2 maps so i'm sure there are more expensive ECU that will do the trick.
nitrous is the same thing, but much safer - just adding oxygen with fuel has anyone ever run nitro in a regular car engine? you should know this brooky, drag race boy
http://www.smokemup.com/tech/fuels.php comparison of energy content of different fuels....check out nitro..... petrol is well crap by comparison
I should change the maps but I didn't What happens is that for a 50k engine you get the damage of a 200k engine don't try it No rings left ;p
petrol A/F ratio = 14:1 nitro A/F ratio = 1.7:1 so your sunny would have been massively lean - no doubt the cleaver ECU would have tried to adjust this but there is no way the injectors would have been able to flow enough fuel lean, lean, and more lean = tatered engine; surprised it didn't just heat seize thinking about this - if you need about 400cc injectors for about 250hp on petrol - on nitro, you would need 3400cc for Nitro. I dont think they exist......nitro dragsters must use carbs?
very old fashioned Lumenition 451 - fuel and spark, without a crank sensor - uses dizzy for timing but it works ok not available any more so at some point I need to upgrade it to something more modern
ahh - I meant nitromethane fuel (as used in top fuel dragsters) - I think it would be a real struggle to get this to work on a regular road car engine
