O.K.... My ABF is getting there. The head is all done with big valves , waiting on my new cams...Got the ITB's, standalone, great exhaust, cold-air box, vernier, raised CR - what else can I do??? I was thinking a Schrick Sump, ARP Rod bolts (got the head studs already), but these won't help the power issue. What about a knife-edged crank? Any other ideas...The new batch of V8's here are VERY, VERY quick...as in, faster than an RS6 quick [:^(] I'd like 230BHP on twin 276's...am I dreaming?
You'll need more than 276s for that power 300+ mate! Worth thinking about gear ratios as well, lower FD etc...
I'm going by the fact that RobT's Ibiza put out 'nearly' 200bhp (199.8 wasn't it?) at Stealth on 276s ITBs etc.. Mad20v's got 'about 240' (200ATW) , with 20 valves - 300deg cams and 8500rpm
Is that 200hp with American wheels though, or British wheels. I am lead to believe that the two are massively different.
It's still a daily driver so don't want to go above 276's...I might have to put in the Mk1 to get the performance I'm after I considered the gear ratios. I might save up and buy a 6spd, plus a 3.94 r&p...that should help it through the gears a lot. Only problem is, if I do end up with it in the Mk1, what gearbox do I use? Not too keen on converting to cable change and I'd guess it would rip the AUG rod change box I have to bits
