I have bought a 16v KR engine from a breakers for 400 and started to remove bits so i could clean it up before putting it in my MK1. I found that the head has been ported + polished and the cam cover gaskets look quite new, it could be possible that the cams are not standard, is there any markings i could look for that will tell me. If they are standard what would be a good cam kit to buy for it.
if they have numbers like 220. then you may have schricks. Cat cams are a viable choice.. (race winners use them in Eurpoean racing.. but not heard of over here.) Good prices and good choice of specs available too. Cat Cams partnr. duration duration maximum lift lift at TDC parts application [data link] [0.1mm+cl] [1.0mm+cl] [cl=0] [cl=0] [-] [-] 7661202 250 / 257 211 / 219 9.55 / 10.15mm 0.55 / 0.95mm O.E.M. HYDR: O.E.M. 7661207 260 / 260 219 / 219 11.20 / 11.20mm 0.90 / 1.00mm O.E.M. HYDR: sport 7661206 260 / 260 224 / 219 11.60 / 11.20mm 1.25 / 1.00mm O.E.M. HYDR: sport 7661210 265 / 262 227 / 228 10.90 / 10.90mm 1.35 / 1.30mm O.E.M. HYDR: sport 7661215 283 / 267 246 / 232 11.50 / 11.45mm 2.55 / 1.70mm O.E.M. HYDR: sport 7661235 275 / 275 236 / 236 11.15 / 11.15mm 1.95 / 1.85mm O.E.M. HYDR: rally & cross 7661221 283 / 279 246 / 242 11.50 / 11.50mm 2.85 / 2.55mm O.E.M. HYDR: rally & cross 7671125 270 / 270 241 / 241 12.00 / 12.00mm 2.85 / 2.95mm custom MECH: rally & cross 7671149 287 / 279 260 / 252 12.50 / 11.95mm 4.05 / 3.55mm custom MECH: rally & cross 7671157 282 / 270 254 / 241 13.20 / 12.00mm 4.05 / 3.20mm custom MECH: rally & race 7671111 282 / 282 254 / 254 13.20 / 13.20mm 4.05 / 4.05mm custom MECH: rally & race 7671167 288 / 280 261 / 253 13.95 / 13.20mm 4.60 / 4.15mm custom MECH: rally & race 7671150 312 / 303 276 / 266 13.60 / 12.95mm 5.45 / 4.85mm custom MECH: rally & race 7671148 306 / 298 277 / 270 13.60 / 13.00mm 6.15 / 5.50mm custom MECH: rally & race Schrick quality at less cost & wider choice Edited by: badger-bill
Yeah they have bits cut out at the bottom of each cam, must be standard. The car is going to be used as a track day/second car, so with me not going to drive it in traffic but not wanting to change to solid lifters, what would be the most sensible choise of duration, what would the valve to piston clearence be? Thanks
