16v webber conversion help
Discussion in 'Carburettor' started by Allan blythe, Feb 26, 2015.
  1. Allan blythe New Member
    Sutton Coldfield
    Hi
    I'm trying to fit a set of 45 webers to a mk2 16v and I need to find out what degree bend I need in the inlet so they sit level of anyone can help that would be great
    Thanks
  2. Sirguydo
    Bolton
    There's a few different manifolds available some better than others .
    As I'm not on cabs I can't think of specific threads just read them and moved on to the next thread .
    Try looking at some of Jon Olds stuff he's a carb man :thumbup:
  3. notenoughtime
    Essex
    The manifolds out there usually require modifying alternator bracket, prices are about 180-250
    Been looking into it as having trouble with k-jet myself
    Mr hillclimer has these made and are highly recommended maybe worth a look :thumbup:
  4. Jon Olds Forum Junkie
    Pretty much all the manifolds you can buy are within the DCOE/DHLA angle tolerance. I'm a carb man? Maybe. I'm a clubman for sure, where VFM matters.
    TB's have many many advantages, such as being to vary airflow at any angle. And I love electronics......
    Jon
    Good to chew this info, as there is always something to learn
  5. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Most manifolds will sit the carbs at the correct or suitable angle. Carbs can cope with a 7 degree tilt...a little more with the float heights re set.
    Our manifold has a slight tilt but not much...all the carb engines that I've supplied them for run fine.
    Be careful of the manifolds with a kick up to clear the alternator...they flow very poorly.
