Hello, I picked up an A reg GTi over the weekend, and the MFA was working - Could select through the functions with the column stalk no problem at all, the only problem I could see then was the MPG function said 99.9 The shift light on the MPG dial at the top of the clocks was also working, but I believe the actual dial is supposed to scroll across the arrow? But it wasnt doing this either. I have now noticed that the MFA is un-selectable and has this code in its place whether the car is on or off, the MPG shift light has also stopped working Does anyone know what could be causing this fault? Please see attached photo Sunday morning I went out to get in the car and I had left the lights on overnight and the battery was completely dead, AA jump started the car as I was away from home so I am not sure if that is relevant information Any help greatly appreciated Regards, Daniel
pull the dash fuse to reset the mfa, check the battery as if dash looses power mfa will play up. for the mpg check the vacuum pipe from the back of the clocks to the brake servo hose
