1986 mk2 gti- which master cylinder is the original bore size?
Discussion in 'Chassis' started by Ken Shields, Jul 20, 2019.
  1. Ken Shields New Member
    Hi All,
    2 are listed by suppliers with 20.64mm and 22.22mm bores. There are other different dimensions described such as overall length and pushrod length, as 2 different servos were used in the 1982-1992 model lifetime.
    Does anybody know the original part number for the earliest type m/c or its actual size?
    or does it matter as many people just bolt on the bigger m/c as an upgrade?
    Thanks!!
  2. GVK
    22mm fitted as an upgrade when fitting larger brakes on the front
