hi there everyone good to be here , i have a mk3 gti 8v with a 2e in it i am after carbing it but want to know if there is such a thing as a x flow head for these cause there is naff all room out the back cheers in advance
Yes there is a X flow head. The head is used on 2.0 litre New Beetles. Do a search on this forum as there are plenty of posts. Just one thing though, what year is your Mk 3? I'm asking because you'll need a cat for the MoT, using carbs you'll end up destroying your cat. I think you'll be better of using throttle bodies if you're thinking of going down the X flow route.
If you're going to the trouble of an engine swap to use carbs I would recommend a 16v. Carbs really come into their own an a higer revving engine it takes a lot of work to get an advantage out of the carbs on an 8v lump. Although, they do sound awesome! I ran them on a mk2 8v although a x-flow lump and I wished I had gone for a 16v, I ended up with better performance from smaller choke sizes as the 8v couldn't suck enough air.
yes, the cooling system needs a few mods but nowt worth worriny about. The flange normally on the front of the head is on the side.
