I am seriously tempted by this engine conversion after seeing what a good drive a Mk2 VR6 is. The engine will run on DTA to save on wiring hassles but what other parts will i need?. Does anyone else have this engine in their MK2 and what sort of power does it produce? Cheers Ben Edited by: MK1Campaign
PhatVR6 is running an R32 lump at the moment in his Corrado. It's causing him all sorts of hassle (VVT and such). I beleive he's using std VR6 ecu 'cus he can't decode the one for the R32 (as yet) - take that with a pinch of salt though, I may be wrong. If you're running DTA it shouldn't matter though, no? Check out his recent 'Bad day at the strip' (or something) thread in Vehicle Chit chat, and his members motors thread (it's about 30 pages long!). Fordo!
The 24V engine transplant shouldn't be a problem but the 4 motion 4WD will be. The system which controls the Haldex is wired in with all the other electrical control systems in the car... i.e ABS, Traction control, Engine ECU etc. If you are serious about 4WD, then I'd consider a VR6 syncro setup from a MK3 rather than the 4 Motion setup. I don't know of one person to have a Haldex running as per factory yet... the only way I've seen it running is with an on/off switch. MG
No I wont be installing the 4wd. Its just the engine install im interested in. I just need to know what other parts will be needed apart from the engine and dta. Cheers Ben
Theres a guy on the vortex who's done this running on bike throttle bodies user name kevinmcd look in the carbs/itbs forum Lee
can't you run it on standard 12v VR6 loom from a golf or corrado? Just don't use a passat loom like the one on Deako's, was a real pain to workout and seperate the engine loom from the lighting loom etc (is all in one on a passat)
I'll have to wind my uncle up then, he thinks his Golf V6 4mo is 30v and keeps winding me up saying it's got nearly twice the valvage of my 2.0 16v Funny thing is, he can't shake me in a race either
Look on the Corrado forum G60renshaw is just finishing off a 24v V6 conversion in his Corrado, 2wd and factory style install, you can't fail to be impressed.
Here's the thread, the 24v stuff is near the end.. 29 pages http://the-corrado.net/forum/viewtopic.php?t=5413&postdays=0 &postorder=asc&start=0 You can't beat the sound of those 24v VR motors (well other than a hi-revving 4 pot on ITBs) Claire's got a K&N typhoon filter on her R32 now, it sounds very nice. Short vid of it going over the mountain @ Cadwell full chat in 2nd..Friday night http://www.aufg48.dsl.pipex.com/mountainwarrp.AVI Edited by: GVK
Usual cable change set up (pedal box,clutch m/c,shifter) 12v vr gearbox with mk2 100mm shafts,modded engine mounts as the lump needs to sit even lower that the 12v,(cant run the car mega low [:^(]) corrado vr rad and fans,mk2 power steering set up (unsure what p/s pump to usewith the 24v). i think thats it....... also instead of modding the mounts ive heard of people spacing the sub frame out from the body.... cant comment on that tho as ive never tryed it. Edited by: FaTT mk1
u don't need to but it would make parking/driving a lot easier epically as the engine is so heavy,valver loves it on his mk2 vr.
