mates Toledo isn't starting the car with key symbol is flashing on dash I did a scan with vagcom got these codes airbags 00532 01044 instruments 65535 control module memory error 00771 01039 01176 65-10 unauthorized-intermittent 01176 07-10 signal to low 01179 incorrect key programming central conv 01330 53-10 supply voltage low 01044 35-00 incorrectly coded I cleared codes but still wont start
aye the black thing roudn the ignition lock. not sure if it can be split off? if you can get a random spare could plug it into the loom and hold it near the key while you try to start it, just to see
