20vt show wrong rpm
Discussion in 'Mk1' started by Flipp_76, Aug 30, 2020.
  1. Flipp_76 Forum Member
    Norway
    Any tips on why my mk1 with agu shows almost 0 on the rev counter when idle?
    Engine idles perfect
  2. davidut5 Forum Member
    Romania
  3. Flipp_76 Forum Member
    Norway
    I have that converter, it was vagtronics who made my loom.
  4. Mk2daz
    it shows completely dead or shows a very low RPM?
    Mine was showing nothing at all and turned out i had a bad earth to the clocks.
    Is your tacho converter definitely wired correctly?
  5. Flipp_76 Forum Member
    Norway
    It shows about 200 when idle, when i rev the engine it goes ut to 2-3-4000. So it works.
    its only little low when idle.
    if its a GTI originally with MFA cluster there will be a male spade near fusebox with brown and brown/white wires in it. make sure this is earthed, originally it would be in engine loom off to the head, but can earth to chassis or claw above fusebox if you like.
  7. rubjonny
    also if you plug vagcom in you can check engine speed measuring blocks, compare this to cluster rpm. see if it really is only off at idle or if its 800 or so low across the range
  8. Flipp_76 Forum Member
    Norway
    It’s not a gti, it’s a 1.5 golf c.
    I will go connect the vagcom and see.
  9. Flipp_76 Forum Member
    Norway
    Seems like it was the cluster.
    Idles now normal
    thanks guys
