256mm brakes???
Discussion in 'Fox/Lupo/Polo' started by mk2vivs, Apr 10, 2011.
  1. mk2vivs Forum Member
    Do the mk2 16v 256mm brakes bolt up to lupo's in particular a 1.4 lupo thats running the standard 239mm set up.I have the mk2 golf 16v complete hub set up. Is it really just a case of putting in ball joints and bolting them up?
  2. mk2vivs Forum Member
    hubs wont fit??
  3. rubjonny
    nope bearing cvarriers slightly different. you need polo/lupo/arosa gti ones. the calipers and carriers are the same as mk2 though, except the later ones use a banjo brake pipe fitting rather than the mk2 std thread
  4. MUSHY 16V
    aberdeen
    you need lupo gti hubs of the same age
  5. mk2vivs Forum Member
    anyone know of any for sale.....;)
  6. mk2vivs Forum Member
    are the mk2 discs and pads usable too?so i could use the mk2 16v calipers/carriers,pads and discs?
  7. rubjonny
    yep mk2 disc n pads all fit
  8. mk2vivs Forum Member
    sound so the hunt for some hubs begins. its a 1.4 lupo would i need to change the outer cv's too?
  9. rubjonny
    no should be fine :)
  10. mk2vivs Forum Member
    thanks!
