anyone ever done back to back on abf cams vs kr cams ? cos I wouldn't mind betting abf cams are better.....a lot more lift !
cheers for the info, this thread should be sticky'd its bout the most usefull thread ive read all year!!!!
Vince at stealth racing is a guru for setting up mk2 16v...well k-jets and many others thats just my opinion but im sure many others will agree
No maf sensor or emmisions to worry about, this build is about old school carb grunt!! No K-jet to worry about either so fueling won't be so much of an issue.. i will be running standard pistons ona fully balanced bottom end with a fairly low CR however so i dont want the the thing to nuc itself with a det problem of similar.. am i right in thinking i want duration rather than lift?? would I be better of with a 268/268 rather than a 276/276?? or is a split 268/267 the best of both worlds?? cheers Henry
Hi, i wanna buy a schrick or dBilas cams. Which are the best for my car 1.8 16V KR ? I going to upgrade to 2.0 head very soon..
Do you mean 2.0l bottom end? Heads are virtually the same when standard Are you doing any head work and maybe lightning/balancing bottom end? Are you running throttle bodies or carbs? All of the above will affect your decision what cams to choose
