280mm Eliptically Grooved Disks+DS2500 pads
Discussion in 'Badger5' started by badger5, Jul 16, 2008.
  1. badger5 Club GTI Sponsor and Supporter Trader
    nr Glos
    Eliptically Grooved Brembo Disks in 280mm available
    We've had the opportunity to get back into the machine shop again and run off a few sets of 280mm 4x100 Ibiza Cupra Brembo disks with ATE style eliptical grooves.
    Priced per pair they are 125+vat
    Combine these with Ferodo DS2500 pads 73+vat and high temp brake fluid 11.49/500ml+vat and you get a brake setup which can withstand this kind of track abuse>>
    {picture courtesy of Daz @ Oulton Park}
    Rears also available for Ibiza Cupra MK3 and Lupo GTi rear to same design - 72+vat/pair
    Grooves are machined with radius cutter within the disk surface not breaking out of the surface so no stres raisers from machining, and are machined to 1mm depth so act as wear indicators also.
    regards
    bill
  2. vwp6n Forum Member
    whats the most upto date price on these Bill delivered?
  3. drunkenalan Paid Member Paid Member
    Leicester
    are they VW discs?
  4. badger5 Club GTI Sponsor and Supporter Trader
    nr Glos
    they can be, or pagid/jurid/ebc
    if VAG ones they will be a little more
  5. richwig83 Forum Member
    If i were to supply you some 345mm discs, how much for the elliptical machining Bill?
  6. f2 ed Forum Member
    Also interested in the above
  7. badger5 Club GTI Sponsor and Supporter Trader
    nr Glos
    Price would be 25/disk+vat and return carriage
    we have done 345mm before for LCR tfsi
  8. bully Forum Member
    Im looking to improve my brakes on my rallye.
    Currently have wilwood 4 pots with DS2500 pads which i am happy with but I think the disks are pretty rubbish.
    I am looking to increase the size of disks and can space the caliper accordingly. Which make disk would you recommend and how much to have them supplied?
    Currently 280mm but looking to go to 310mm as i have 16" comps so know there is room
