Quicky,i can get a recon'd 2H head for 120.Part no 026103373AA.The guy says it's a straight swap into any 1.8 8v.Is this true ? Thanks.
Should do... AFAIK it`s only the inlet manifold that differs between the 2H and other 8vs (PB, EK, etc) Someone else will confirm...
Cheers,is there anything i can visually check to see if it's been properly recon'd and what size is the inlet valve on the 2H.
