4-5 stud conversion,HELP.
Discussion in 'Chassis' started by markone, Aug 21, 2010.
  1. markone New Member
    Can anyone tell me where i can get 5stud hub's that will fit into my existing 4 stud hub or can i change all wishbones roll bar and carriers-calipers from a VR6 and still use my 1.9 tdi suspension as they have new gti shockers,thanks.
    Bump.
    So are all 5-stud hub flanges interchangeable into 4 stud hubs? Are the bearings the same? ie the OD of the hub flange is the same for both?
  3. rubjonny
    rubjonny Administrator Admin
    MK3 5 stud hubs fit late MK2 bearing carriers, late MK2 and MK3 bearings are the same diameters. only difference between late MK2 and MK3 5 stud bearing kits are some of the nuts/bolts that are included
