4+e
Discussion in 'Transmission' started by Jolfa, Jan 24, 2004.
  1. fthaimike Forum Addict
    Dont know what mine is yet, all i know is that the box was a full rebuild with a quaife diff (diff bolts not pins) but the owner done 100 miles & found out his car couldnt pull in it properlly because of his smaller engine?
    Been told it has small 1,2 long 3 & overdrive 5th but this is what a 4+e box is anway i think?
    In a full rebuild exactlly whats done or changed?
  2. GVK
    Hopefully it's had **at least** a 2nd gear synchro replaced and all new bearings,gaskets and seals and any other worn parts replaced as required.
  3. fthaimike Forum Addict
    Well im paying 1200 from TSR & was told it's a full rebuild so i hope so [:$] .
  4. golf1.6cl Forum Member
    Yea you need to go 55 in second to get a similar rate of acceleration in third. If you change at less than 40 the pick up in third is crap.
  5. JEZ
    Jez Forum Member
    when tsr fitted my recon 'box (020 ACD) Tim said they'd fitted a 4+E 'box and not to worry about the car showing less on the rollers due to a taller 4th gear. I was like "jiber, jibber, you've done what?!!"
    I had a 4+E 'box in my first golf (1.6 cl) and it would go quicker in 4th as 5th was way too tall for the lil 1.6 to accel in (ahh bless it :p)
    Thankfully they had fitted the 'box i'd asked for...another 020 ACD and all was well. Even with the diff it would still spin up a lil in 2nd in the dry [:D]. Top speed was 129mph with my 195/45 r15 tyres ;) and would hit the limiter in top very easily.
  6. Tubthumped Forum Junkie
    Hebden Bridge
    JESUS!!!! [:s]
    There is a full Quaiife box and diff going close to me for 1200.
    And i paid a bit less than what you have for mine... and it's only missing the diff.
  7. Jolfa
    Jolfa Forum Junkie
    Queenstown - New Zealand
    ok whilst were on gearboxes, (yes i know rick, you've alreaddy told me but..) why does my 4+e gti box feel so sloppy and poridge stirrrrer like compared to my 4spd 1.3?
  8. Riley
    Riley Forum Addict
    Burnley/Lancs
    worn linkages?
  9. Jolfa
    Jolfa Forum Junkie
    fixable? cheap? easy?
  10. Riley
    Riley Forum Addict
    Burnley/Lancs
    gsf do 2 kits,1 with bushes about 10 i think and 1 with everything,including the plastic ball at bottom of gear lever(comprehensive kit)about 20.
    totally transformed mine.
  11. mr purple Forum Member
    Northern Monkey
    The bushes only kit is 4.75+VAT from GSF, although they go on E bay for around 15, why people pay that I still have no idea.
    Edited by: mr purple
  12. fthaimike Forum Addict
    So im getting a good deal then?
  13. JEZ
    Jez Forum Member
    The diff is about 500 new from quaife, so the other 700 is for the recon 4+E 'box and labour...
  14. Tubthumped Forum Junkie
    Hebden Bridge
    [:s] [:s]
    I think thats very expensive to be honest.
  15. Tubthumped Forum Junkie
    Hebden Bridge
    bit actualy meant a lot.
  16. prof Forum Addict
    Suffragette City
    tubs
    vince charges about the same
    sure 800gs or Fozzie would be cheaper
  17. Tubthumped Forum Junkie
    Hebden Bridge
    I know Vince charges the same.. think it expensive paying that much for that spec from anywhere..
  18. fthaimike Forum Addict
    Yeah i wanted something i can rely on so got this one from tsr as i never had any problems with them in the past
    EDIT money to burn ;)
    Edited by: fthaimike
  19. JEZ
    Jez Forum Member
    the diff is worth every penny :p
  20. fthaimike Forum Addict
    Just hope my engine can pull strong with that box [:s]
