5 door Golf All electric windows stopped working
Discussion in 'Mk3' started by paulm2322, Oct 5, 2022.
  1. paulm2322
    paulm2322 Paid Member Paid Member
    Liverpool, UK
    This is a bizarre fault. I used the car this morning and the windows were working fine. I've just picked my children up from school and none of the windows are working, front or rear. The electric sunroof is working fine.
    Has anyone had this issue before? Not sure where to look. There is nothing on the fuse board for windows.
    Thanks,
    Paul
  2. paulm2322
    Liverpool, UK
    I've found on internet number 24 relay is supposed to be thermal fuse (20A) – power windows. Haynes manual is saying relay 6 is thermal fuse for electric windows.
  3. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    There's a 20 amp thermal fuse 'above the relay plate' apparently. May be worth checking that hasn't somehow gone permanently open-circuit.
    Some photos of one in this thread, I doubt they changed between mk2 and mk3: Thermal fuse for electric windows | Club GTI
  4. paulm2322
    Liverpool, UK
  5. paulm2322
    Liverpool, UK
    Also, according to Haynes (I know they aren’t reliable) it’s relay 6 (top right of diagram). When I look at my fuse board, the top right relay is 191 and looks nothing like the above thermal fuse.
  6. EZ_Pete
    Can you post a photo of the relay board?
  7. EZ_Pete
    paulm2322 likes this.
  8. paulm2322
    Liverpool, UK
    Aha! Brilliant Pete. I tried taking a photo of relays but was too tight to get phone up there.
    I know where to look now when replacing the thermal fuse so will order one now.
    Cheers.
  9. paulm2322
    Liverpool, UK
    It doesn’t seem to be in the same location on my fuse board. Not sure if I can just see the edge of it above the white relay?
  10. rubjonny
    thats the thermal fuse yep. have you also checked the main fuses, one of them is the ignition live which triggers the windows. to test if thermal fuse is ok test the total closure from the door lock, hold the key 'unlocked' windows should roll down, and 'locked' windows should roll up
  11. rubjonny
    fuse 14 for electric windows plus a few other things, reverse lights for one. check the wiring to the switch and switch itself (or just check if reverse lights work I guess :lol:)
  12. paulm2322
    Liverpool, UK
    Hi Johnny,
    I’ve got rear door handles on the front of car so can’t do that test. I opened sunroof and then pressed close on alarm key fob and the sunroof closed via total closure. Does that mean it’s not the thermal fuse?
  13. rubjonny
    sunroof has its own fuses, just swap the thermal fuse with a standard fuse for now and try a window, if it works then its the fuse if not its some other issue
  14. paulm2322
    Liverpool, UK
    I will check these fuses after I’ve got children from school. Will lost back here with result. Cheers.
  15. paulm2322
    Liverpool, UK
    Ok. Will give that a go and let you know.
    thanks
  16. paulm2322
    Liverpool, UK
    Johnny!!!!!!! I am at the virtual bar buying you a pint right now!
    It was fuse 14. All windows working again.
    Many thanks for everyone’s advice and help.
    Paul
    EZ_Pete likes this.
  17. rubjonny
    Its too early for a virtual beer now, I'll take a virtual coffee instead though :lol:
