50mm Inlet
Discussion in 'Engines' started by mk1Matt, Jan 19, 2005.
  1. GVK
  2. prof Forum Addict
    Suffragette City
    wonder if yours has had a skim craig, it seems to make loads of welly early on, about 30ftlb more than IanB at 2.5k
  3. GVK
    Surely that 'cos it's got standard KR cams, mine had much more torque lower down (well all through the range actually) with those...
  4. HidRo Forum Member
    Portugal
    :thumbup: OK! It was just a question... Don't take it the wrong way though.
  5. RobT
    RobT Forum Junkie
    Cheshire
    Interesting results - shame to miss all the fun - maybe next time
    Cheers
    Rob
  6. kevh Forum Member
    hi gary,got a 42mm manifold on my 16v cab and iwidened itall the way through approx 2mm . on standard 1.8 it pulled to 7200 in third and fourth cleanly. it reved like f...k. ;)still reading your thread top stuff m8 :clap:good result at stealth to. paul h
  7. ianb Forum Member
    Interesting graphs
    My car had poorer curves for power and torque than in the summer, [:^(]
    The car was running less timing and was freshly set up by Vince when the WUR mod was done.
    Perhaps another set up may be on the cards but at the end of the day on the road it feels very strong at all points from low down to the top of the spectrum where it's best.
    My power ATW was poorer in the summer than on Sunday. [:s]
    Grahams car had lower ATW figure on Sunday..154hp v 168hp on my car but his tranmission losses was due partly because of his 2 degree camber......it's all relative.
    Tubs torque looks very good....perhaps Gary can post my old graphs on his site against the most recent day to see where I've lost most torque.
    Still the power and torque on my car will look isignificant compared to our MKIV....but I'd still like more.
    Ian
  8. GVK
    I've not got the files Ian, think Prof may have them?
  9. velly_16v_cab
    velly_16v_cab Forum Junkie
    Melbourne, Australia
    sure will gary...there willl be some egos lost on that day :lol:
  10. Aquablue Forum Member
    Medway, Kent.
    Have you done it yet? Would be intersted in hearing your views as to whether there was much difference at all?
  11. gti_kev Forum Member
    Swansea - Wales
    How do you tell which manifold you have? meaure it yes, but where?
    Sorry for the dumb question!
  12. Aquablue Forum Member
    Medway, Kent.
    To get a proper measurement you need to take the inlet manifold off, then measure the width of the holes in the manifold 'pipes'. But just by looking at them, I've noticed that the 42mm one's have straight 'pipes all the way down, whereas the 50mm one's get fatter half-way down the 'pipes'. Also in he 42mm one, the gap between the pipes where they leave the top is a stetched upside down 'u' shape, whereas in the 50mm one it isn't! Telling the difference that way between 42mm & 40.5 mm would be very hard though, I would have thought!
    Edited by: Aquablue
  13. Aquablue Forum Member
    Medway, Kent.
    Check out the differences between them in these pics!
  14. gti_kev Forum Member
    Swansea - Wales
    Cheers, Yes i can see the difference!
    I'll have a look, just curious ;)Mines a November 89 16V so one of the first as i think they came out in August 89
    Thanks again
  15. gti_kev Forum Member
    Swansea - Wales
    Mines definatelly a 50mm one!
    So where can i get a 40mm one from and how much?
    Also how much is the gasket sets?
  16. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    Gaskets about a fiver for both from GSF for the 42mm. The upper gasket for the 50mm is VW only and is 14ish.
  17. gti_kev Forum Member
    Swansea - Wales
    Thanks!
    If i remove my 50mm one and I don't like the 42 0r 40mm (if i can get one) can i re-use the 50mm gasket if it's in good shape?
