i need a definitive answer please as this is the cause of much stress and headaches. are your 8v cams ground to run at standard timing marks or eqal overlap at tdc? i keep getting told eqal, but that is 2 teeth retarded from standard marks!! so what should it be out the box. id like to set it as it should be so the belt doesnt have to come off on the rolling road. cam in question is tsr 103 on a pack c solid tappet head. how long is your waiting list for setup, whats the rough cost and do you chip the mk2 digi ecus? thanks
