8v pb wont crank.
Discussion in 'Engines' started by Matt82, Jan 4, 2008.
  1. Matt82
    Matt82 Forum Addict
    GTI Scene
    LBFT gains are the only gains that matter
  2. SplatterHaus Forum Addict
    Sunny Shoebury
    Surely you don't need any more torques, its an 8v......
  3. Mike_H Forum Addict
    There are two small connectors on the starter (on some starters) on the Mk2. You've probably got the LT wires mixed up. It's an easy mistake to make. The Battery should earth to the gearbox, incidentally. Either that or you've mixed up the thick cables.
    Take the spark plugs out to rule out a cylinder full of fuel... the engine bay probably needs a petrol wash anyway ;)
    If you have blown the ECU, the engine should still crank. What's the level on the dipstick? Cylinders full of fuel would tend to fill up the sump.
  4. drunkenalan Paid Member Paid Member
    Leicester
    if the cylinders are full of fuel take the plugs out and crank it over, but make sure a) the car it outside & b) the coil lead is removed, a 10ft fireball isnt a great deal of fun for you,your car or your garage. altho it looks good for any spectators!
  5. Matt82
    Matt82 Forum Addict
    GTI Scene
    an oil change was pretty much the next job anyway.
    the earth was originally on gearbox mount bracket and thats where i replaced it too
    if that point is not earthing nicely, do you recon that could be causing it not to crank?
    i dont even think the solenoid was doing its click either actually
    any idea which way round the who spade connectors should go. i did copy the layout on the GPES but that didnt seem to work haha
  6. Mike_H Forum Addict
    On the earth strap, it could be the problem, but unless it's really dirty or loose, it should be OK.
    Swap the spade connectors round. I've made that mistake in the past.
  7. rubjonny
    I had exactly this, was a poor earth. luckily after I left the car for a short time and re-did the earth it fired up and has been fine ever since! Early MK2s have the gearbox earth on the top of the gearbox mount bracket near the front, which is a rubbish location tbh! Later MK2s and MK3s have a stud on the end of the rear gearbox -> engine bolt, much better! I'd suggest you upgrade to the later type if you can. I also fitted battery cables off a 93/94 Passat, nice n chunky and the battery clamps are a much better design.
    Heres a pic of my bay, you can see the Passat cables and just about make out where the better gerbox earth ends up :)
  8. Matt82
    Matt82 Forum Addict
    GTI Scene
    sweet mate
    thats the first thing i do tonight after i get my thermals on, tools out and get my ass down to 8v [:D]
    i dreamt about driving it lastnight, it was a good dream lol
    glad you posted ;)
  9. rubjonny
    Oh and to check if ECU is blown turn the key 1 click, if the pump just runs continuously its blown, if it primes for a few seconds then it should be fine :)
  10. Matt82
    Matt82 Forum Addict
    GTI Scene
    whilst the box was out, i hung the clutch cable from the bonnet and syringed a load of oil down it. the clutch action is now super smooth. worth doing if your clutch is feeling ghey/sticky
  11. jamesa Forum Junkie
    Abz
    Mk2 16v starter
    Had the same `no turn over` problem on the Mk2 16v, cleaned up all the starter connections and OK since.
    Not sure if the 8v is the same as this ?
    Matt ... I`ve a spare earth lead that fits to the gearbox from the battery, it is sound .. I previously replaced it during a wiring `frenzy`. PM your address tonight if you want it, can post tomorrow but then am away for a week.
  12. Matt82
    Matt82 Forum Addict
    GTI Scene
    i got it to crank. i had to rig up another earth and it cranked first time.
    the cylinders were full of petrol after mucking about with it last night. this crazy car fired and ran first time, it is insane how easy it starts haha
    i love it!
    cheers you sexy boys for helping me out
  13. Aphex Forum Junkie
    So.. hate the mk3 yet?
  14. TheSecondComing Forum Addict
    Does it have any FURY though?
  15. Matt82
    Matt82 Forum Addict
    GTI Scene
    its got FURY but in its own special way [:D]
    if i wasnt so poor id consider puttting in the actual ABF POWERHOUSE OF FURY and my god that car would be special because the car has so much spec as it is, it makes so much sense, but then what would i do with the rest of the mk3?
    as for mk3 compared to mk2, its only took 50 miles or so, but the mk2 is nicer by about a country mile. it is just shocking how good an 88 E reg car feels, but then this thing has been pampered its whole life
    there is more pampering to come. a trip to VW to get new gearbox oil and then a trip to GSF to get some fuchs then im going to go ape under the bonnet again making sure earth wise it is tip top.
  16. TheSecondComing Forum Addict
    Is this your own, then? I was off the net for a while, no idea you had a proper car as opposed to a grannywagon. Get all the gearbox bushes as well as the oil, it'll feel like a new box! Or Redline MTL is a better oil IMO, but there is not much difference.
  17. Matt82
    Matt82 Forum Addict
    GTI Scene
    it is my own. it has got a recent rod change bush kit fitted. ive felt the difference between old mk2 bushes and new ones, this does feel pretty lush.
    im gonna head down to the local vw place now, i know the parts guys there well, theyll love to see this thing [:D]
    I REALLY SHOULD NOT BE KEEPING IT!
  18. rubjonny
    sell the MK3, use proffits to buy ABF + shiny things [8D]
  19. Matt82
    Matt82 Forum Addict
    GTI Scene
    id like to put my own ABF in there [:D] if i keep the mk2 subframe i can keep the eibach ARBs, if i got for the mk3 subframe i get the big brakes and widetrack
    but then what do i do with the rest of the mk3?
  20. TheSecondComing Forum Addict
    They're all rustbuckets anyway, fill it with old engine blocks and weigh it in!
    MyMk2 16v is sitting in the drive at the min, I'm driving a HORRIBLY boring Skoda Octavia diesel. Both probably soon to be gone, in exchange for a 535i sport.
    I still have the ratty caddy though, gotta keep in touch with your roots....
