im looking for advise on a late 9a oil filter housing i need one for a engine im fitting into a audi 80 and cannot find one. the part no is 053 115 405f. does any one have one or know what other ones will fit. it needs to be the ones at 45degs with the ofset bolt at the top.
same as most big block mk3 golf ones, you'll have much better luck trying to find one of those edit: ah sorry! you want late audi one to fit a later 9a lump right? if so you need later 2.0 16v ACE code housing. The later 8v ABK/ADW etc ones will bolt to the block but the part number differs for some reason? not sure why
