Hi all, the car is a 2008 2.7 tdi v6 As i start it up the cooling fans start running even from cold ? it get to running temps and still the fans are going for it they only go of after the key has been pulled. any ideas, before i take it to get put on a diagnostics and pay a blooming fortune cheers grant
a friends a3 3.2 did this his was the engine temp sensor it also needed the fault code cleared before it stoped running all the time he was told it could be the fan unit by someone else would be worth getting someone to read and clear the fault codes may be someone with vag-com on hear that could help i'm a bit to far away to do it
if it's not the above and is the fan modual there is a recall for the fan module recall 19f8 could be worth looking to see if you car is covered
next door neighbour has a friend who works in a Audi garage and is going to check on the system for the recall thing, vag com maybe a bit hard to come by, i do have mates that own and work in garages so will ask them all the research i have been doing as come up the same hope its simple and thanks for your help
