Aaaaagh..... (Updated)
Discussion in 'Engines' started by TheSecondComing, Oct 31, 2003.
  1. pigbladder Forum Addict
    cambridge , uk
    oh..and are you sure its the right dist(not kjet?dunno if they interchange?) sure its timed up right?...you could twist around each way while its running and see if it sounds sweeter?
    dont mean to insult you ,but are you familiar with vw timing marks?..i had some agro once cus i timed it on the "0" instead of the "v" or vise versa
  2. TheSecondComing Forum Addict
    It sounds tractory -loud, slightly lumpy idle, louder than normal exhaust, very occasional backfires, not rattley. It was definitely the right dizzy as well. I'm more than familiar with VW timing marks and the IGN timing is spot on - but it's raining, and I can't be arsed to go out and start checking cam timing! It's been like this since I bought it on Thursday. I'm beginning to strongly suspect the timing belt is one tooth out....... it feels for all the world like driving a low compression engine, which would bear out the timing belt theory! I might drop it into the local VW specialist and see if he'll check it for me - by the time I get back from work it's dark! He's cheap and he knows his stuff, and it beats me lying on a wet driveway! It'll be the first time I've ever taken any car to a garage.....Any other input would be much appreciated!
    Edited by: TheSecondComing
  3. pigbladder Forum Addict
    cambridge , uk
    i spose a miss aligned belt sounds likely.although would it make it it noisey??..another digi prob ive found is the inj harness gets dry and cracked,dont really sound like that though
  4. TheSecondComing Forum Addict
    Aye, I think the misaligned belt lets the still-burning mixture out too early, hence the noise...... I'll see though, the garage bloke will probably find something else completely.......
  5. TheSecondComing Forum Addict
    Right - an update. Took it out for a run tonight. A bit slow to start, idle is still a bit crap. It won't even rev freely in neutral (is this a clue). Went on the road - no power at all until it warmed up a bit, then I was able to use 2nd gear as well as first (oh joy!) It is far, far slower than a 1 litre Nova - unusably slow to be honest. Backfired once, but just generally crawled along like a slug. Totally powerless. Is the money still on the slipped cambelt, or does anyone have any ideas? It won't even make it up a hill......
    Could it be the coil? I have a spare one.... rotor arm, dizzy, leads etc are all new as I mentioned. No signs of a hg leak. Any and all suggestions are welcome - it's driving me mad! It won't even make it up a mild hill without a big run-up......
  6. Tuff Schmitt Forum Junkie
    Hepatology Ward
    Parz, listen to me...
    Replace the cambelt.
  7. SiVWW Forum Member
    Northern Ireland
    Yup.... change the Belt......
    if you want a good guy to change it and set her up, contact Hugh Palmer in N'ards..... he is bloody good!!!! and knows GTi's inside out.
  8. KeithMac Forum Junkie
    Kazakhstan
    If it`s not the belt, it sounds like it`s off a pot. Have you done the usually removing plug caps on idle and seeing if the revs drop?
  9. TheSecondComing Forum Addict
    Yup, it makes no difference - taking it to a bloke at 3pm today for him to have a look. I hate working on cars when it's cold........
  10. TheSecondComing Forum Addict
    I feel deeply ashamed. Guess what the problem was? Two plug leads on the wrong plugs. The only thing I didn't check. I've been building engines since I was 12 and I failed to notice this. Please forgive me......
    Runs like a champ now though. Brand new set of leads on it when I bought it at the auction - my guess is the owner bought new leads, fitted them wrongly, then sold it at the auction because he thought he's fucked up something badly. Which means I got a 1500 car for 600 - yay! Apologies for wasting your thinking time, fella's.....
    PS. Must get a set of those insulated pliers so you can pull off plug leads while the engine's running.....
  11. pigbladder Forum Addict
    cambridge , uk
    sweet ..at least your up and running now!
    you should have lied and said you fixed the ecu with a kit kat wraper and some calculator parts..we'd have been impressed then
    Edited by: pigbladder
  12. KeithMac Forum Junkie
    Kazakhstan
    At least it was a cheap fix!
  13. TheSecondComing Forum Addict
    Aye - I was thinking "head gasket"..... though it's had a whole new VW exhaust this year, including manifold, so the evil manifold-downpipe bolts should have been easy. But I did not want to do it! I am probably the most chuffed man on earth at the minute!
  14. Paul Forum Member
    Antarctica
    lol [:D] [:D] always remember 1-3-4-2 ;) ;)
  15. AMY
    Amy Forum Member
    England
    LOL!! [:*:] [:o)]
    we did that when we tried to start the raddo .... :p [:o)]
  16. Golf-Fiend Forum Member
    Home
    ..wimp ;)
  17. madmk4 Forum Member
    Unless it's certain fords ;)
