ABF 60-2 trigger wheel sensor position
Discussion in 'Throttle bodies & non-OEM ECUs' started by altern8, Apr 27, 2010.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Hi,
    Does anyone know what the wheel sensor position should be set to for a ABF 60-2 wheel?
    This is what mine is set to but I think it could be wrong
    Cheers
  2. altern8 Forum Junkie
    Is this right
    it's like the other vw motors (ABA, VR6, 1.8T etc), it's 60-2 and you can use it .. set to 78 deg
  3. altern8 Forum Junkie
  4. altern8 Forum Junkie
  5. altern8 Forum Junkie
    Tell me if I'm typing crap here
    VR sensor align 14 @ TDC?
    14 -1 = 13
    13 x 6 = 78
  6. infinity
    infinity Forum Member
    yep mine is set to 78 degrees, but double check with a timing light once you get it up and running.
  7. Toyotec
    Yes TDC is at tooth 14 on these.
  8. altern8 Forum Junkie
    Thanks both, hopefully it might start today :)
  9. altern8 Forum Junkie
    Still no joy using the 78 setting, with it set to 114 it would fire and spark but didnt on 78
    Bloke at emerald said it was 85 for the older vw 93 -96 ( i think) or for the newer stuff 120
  10. altern8 Forum Junkie
    Update, 85 works for some reason I'll change it to 78 once its all running. Not sure why it didnt work first but put a new battery on to help it turn over and off it went :)
  11. altern8 Forum Junkie
    78 seems work fine also had to set the starting tooth to 1 instead of 0
    Should the timing on idle be set to 6 degrees with the gun when ideling about 900rpm?
  12. Brookster
    M1 J40
    i would have it idle at 15 degress thats what mine is.
  13. altern8 Forum Junkie
    is yours a 60-2 wheel too? 15 sounds high for idle
  14. Brookster
    M1 J40
    no i'm running off the Dizzy Hall Sensor.
    i used to 12 deg advance when i was on k-jet .
  15. tshirt2k
    tshirt2k Forum Junkie
    Herts
    15 on mine is used for cranking. When running it has a setting of 13. But i also have an idle advance control that reduces angle to 8 once over a certain temperature. This is because the idle seems to increase too high as it gets warm. The idle setting helps to keep idle around a 1000.
    Its due to the base idle setting needed for cold starts as i dont have an ISV yet.
    A lower spark angle at idle also recuces HC, which i need when MOT time comes around. Doesn't run as smooth though.
  16. Brookster
    M1 J40
    mine reduces to 8 deg when warm too ! Must be a Toyotec Map :thumbup:
  17. tshirt2k
    Herts
    It must be a coincidence it goes to 8. I changed that myself to get the idle right in cold and warm conditions.
  18. Thonn New Member
    Mine goes to 8 too.
