Hey. I thought better if is ask it first. I must replace the original downpipe on my LHD tubular exhaust manifold. Which way is easier? Remove the complete manifold with dp from above or just the dp and 6 big nut from under? The exhaust system is untouched yet so i gess will be not too much fun.
I would start by seeing if the 6 DP nuts will even crack loose, if you can get them undone then you're sorted its nice and easy job from there. main thing is access and hoping the studs dont shear
