ABF G60
Discussion in '16-valve' started by Corradoboy18, Jan 17, 2022.
  1. Corradoboy18 New Member
    I think it's possible.
    I was taking the g-lader off of a G60 for a friend and saw that the water pump is exactly the same. The bolts extend much further on the PG to accommodate the supercharger mount bracket.
    It lines up perfectly with the ABF.
    So, theoretically, Its possible to have a G60 ABF.
    Thoughts...please. because I'm about to go down this rabbit hole and run Mega squirt just to prove I can
    It has been done before, I haven't seen one in a long time though.
    The question is.... Why? When there's better, more efficient ways to get the power?
  3. Corradoboy18 New Member
    Because it's factory VW tech and think it would be wicked to open the hood and see a g-lader with an ABF. I'm not going for ultimate power. Just something worthy of a good conversation. I'm not Set on this idea. Just noticed that it may be possible.
  4. Tristan
  5. Corradoboy18 New Member
  6. Schtirlitz New Member
  7. nass Forum Member
    I have a brand new bbm 16vg60 integration kit for sale
  8. Toyotec
    Nothing new.
    There were VW MK3 ABF cars, you could pay VWMS to upgrade to a G60 lader and lowered compression. Some 210ps and 287Nm was said to be achieved ( slow in todays world).
    The original ABF XXX XXX number was re numbered into a "3G" serial number when an ABF was upgraded to G60 parts. Old KR/PL/3G bracketry was carry over.
    One of those engines came up for sale over on the group.
    www.vw-racing.org
    db0932_1a06425b16864be981aa2f781e16e7b0_mv2.jpg db0932_eca835e258f747d1a02aee5e8489f893_mv2.jpg db0932_9a8bdcace4f44a79b1977eea46fda22c_mv2.jpg db0932_044782b7b0da48fda9b9056b15c408f8_mv2.jpg db0932_cfe17900da234fc5a8419300ca160a46_mv2.jpg db0932_08b74235781548e9a2470e478ef770e5_mv2.jpg
    An outfit I know well, damaged a 3G engine. So I spec'd them an ABF engine to acting in the place of the 3G. As I said all the parts are carry over.
    I will say, there are better ways to get cylinder fill into an ABF, so do think through why you would want to spend time and resource in the direction above.
