ABF Lambda question when hot
Discussion in '16-valve' started by Gman2oo6, Jun 24, 2020.
  1. Gman2oo6 New Member
    Netherlands
    Ok cannot figure this one out
    Replaced my lambda ( original OEM ) because of high fuel consumption ( 55 litre on 400km )
    also because the car will fall out when it is hot it drops to 400 rpm and then jumps op again
    now what is really strange is when i disconnect my lambda all is fine it runs like it has to do
    but i think it runs in save ranges the ECU provide the car to run with
    But why does it do this when i reconnect my lambda and only when the lambda starts to work ?
    in cold start all is fine
  2. Savagesam
    Did you buy a decent OEM quality part? I've not had any luck with anything other than Bosch on my VW's
  3. Toyotec
    When you disconnect the HEGO, the fuel mixture defaults over 10% richer.
    This suggests either your HEGO is not compatible with the ECU or you have an air leak.
    Regarding your original problem, I suspect you have other maintenance issues.
  4. Gman2oo6 New Member
    Netherlands
    Original Bosch 0 258 003 584 Lambda is in it
    air leak test i did it with brake-cleaner
    spaying it when the engine runs no fault there
    Maintenance issues ?
    All that could be replaced is done with OEM parts
    All sensors , All filters , All liquids ,Spark-plugs , timing-belts , Chain , Hoses , .....so all you can think off
  5. Gman2oo6 New Member
    Netherlands
    hmmm with the Lambda disconnected it now starts to do the same less heavy as with lambda .
    down to 400 rpm hiks 2 times and then settles at 750 rpm
