Abf not fitting into my mk2
Discussion in 'Mk2' started by James McCormack, Nov 13, 2019.
  1. James McCormack New Member
    Abf not fitting in. Hi guys I need some knowledge on a abf setup in a mk2 Jetta 91.. it was originally a 1.6sd and I dropped all about and yr ago and I dropped in a full abf setup from a mk3.. I used the mk3 subframe and all the mk3 mounts and every nut and bolt from it.. when I dropped it in I noticed it was a little off and it was rising from the rear left mount.. i just put the bonnet on to see if it was too high and it is.. the bracket of the abf mk3 setup is rising up the engine.. it’s the 3 hole bracket.. what bracket or mount would be best used to sit it down thanks for any help
    How do. If your rear bracket has 3 holes in it then its a mk2 version, the mk3 bracket only has 1 hole in it.
    what gearbox are you using?
