ABF on ITBs not revving up
Discussion in 'Throttle bodies & non-OEM ECUs' started by Vörös Marcell, Apr 8, 2024.
  1. Vörös Marcell New Member
    Hi guys,
    last week I installed a modified 50mm ITB on my stock 2.0 16V ABF Golf 2 rallycross car, but I couldn't drive it because it wouldn't rev up. When I floor it, the car starts to pop and bang on a low rpm like launch control. But if I play with the throttle, I can rev it up, like giving 2 or 3 half pushes, then floor it, it revs up to the limit. It has 269ccm 1.8t injectors, 3 bar chinese fuel pressure regulator, stock throttle position sensor, stock ECU. One thing is I don't know if it's important or not, but I didn't put any vacuum line on the ECU.
    Sorry for my bad english, I am from Hungary.
    Thanks in advance.
  2. PhilRyder
    50mm seems a lot for that engine would be my first thought.
    However, have you balanced the ITBs?
  3. 2swe Forum Member
    Czech Republic
    it is not going to work with stock ECU.
    Steffen likes this.
  4. daNpy Forum Member
    NL
    Isn't the vacuum line supposed to tell the ECU to enrich fuel for acceleration? Or is that completely calculated from TPS signal steepness?
    I think so too, in anyway you won't get the power out that you are able to get with this big intake setup.
  5. Vörös Marcell New Member
    I put a vacuum line on the ECU from the ITB and it solved the problem, now I have proper idle and really good throttle response, and now the engine revs as it should. I will take the car to a dyno and test it with the stock intake manifold and the ITB to check if it is better with ITB or not. Thanks guys!
    PhilRyder likes this.
  6. Tristan
    Yeah sounds like your ecu uses MAP and didn't know the inlet vacuum.
    GVK likes this.
  7. KeithMac Forum Junkie
    Kazakhstan
    Ideally you want a Wideband fitted and datalogging before you attempt to drive that.
    As said above I'd expect it to be running massively lean as it stands now.
    Vacuum was you should take a line off all 4 and merge them together.
    Most Throttle Body setups run Alpha-n or blended Alpha-n (TPS based load).
    tomasson and daNpy like this.
