ABF Wiring help.
Discussion in 'Throttle bodies & non-OEM ECUs' started by Volksmk1, Apr 9, 2017.
  1. Volksmk1 New Member
    Hello! Im new here and my english isnt the best but i hope you guys can help me :) I would like to know if i can controll ignition with a stand alone management system on an standard ABF engine while using carburators for fuel..
    Im not sure what needs to be done and what it is that needs to be connected for the ecu to do this..
    I have a EMU ecu / Ecu master to controll ignition with.
    The car is an 96 mk3 ABF 16v.
    I hope you understand my question :)
  2. Toyotec
    Of course you can.
    Replacing an ECU on a car is not the same as changing a spark plug and if you are not sure what to do then I would suggest contacting a tuning specialist in your region.
