AGG Oil Filter Housing
Discussion in '8-valve' started by bmouthboyo, Jul 19, 2018.
  1. bmouthboyo Forum Member
    hi guys can anyone tell me the torque setting or link to an in-line resource showing for the oil filter housing and crank breather hex bolts?
    My Haynes manual doesn't seem to cover all the torque settings for ancillaries. Anyone know where I can find them online?
    Thanks
  3. bmouthboyo Forum Member
  4. bmouthboyo Forum Member
    Do you know where on that website the sensor torques figures are? Such as flanges, crank sensor bolt, knock sensor bolt etc?
    I broke the crank sensor bolt today as I couldn’t find the torque figure in my Haynes or online and went with a forum post that said 20Nm and it snapped! Luckily I easy outed it.
    Thanks
  5. rubjonny
  6. Tristan
    Slightly off topic, but make sure you have metal to metal contact between the filter housing and either the mounting bolts, or the block (unlikely ,due to the gasket)
    With the paint or powdercoat, the housing may not be properly earthed, and will cause your oil sensors not to work properly.
    A star, split or similar lock washer under one bolt should suffice .
    jamesa likes this.
