Easy Now... I need to flip reverse my inlet so that it's on the other side to accommodate a stinking turbo on the right of the engine... Currently the APY feeds from the right. Can I use an AGU inlet or other to flip that to feed from the left? Ideas please.
AGU inlet is big port, APY is small port so do not use it. There is a reversed 1.8t inlet used on sharan 1.8t engines that is small port and that you can use.
I completly misread your question. If you have a small port head (APY) and you want to feed from the left than you need a AJQ inlet (there are others too) Sorry for the confusion!
