right iam getting bord of not getting this fixed ! the alarm is a piranha the problem is i prime the alarm (on) and then after around a min the alarm goes off... so i have no alarm or immo atm! ive traced all the wires and there are two that are very concerning, one is a very thin green and yellow wire that comes out the back of the alarm/immob and just hangs loose *see pic below ive tryed connecting it to the pos on the battery and the negative with no luck. i also found this wire it seem to have quite a thick shiney plastic coating, its about 3 meters long this also comes from the back of the alarm and through the bulkhead , i found it just under the carpet next to the passenger side door, the wire just seem to end.... this is the alarm cheers, any help is great!
its for the alarm, so the remotes work from a distance, that green and yellow wire doesnt go to the bonnet switch at all ?
...or if it`s been installed `properly`, it`ll be up near the scuttle... And, yes, the aerial is for the alarm. That`s how your remote fob works...radio frequency...
does that green/yellow wire come from the alarm unit or from inside the car,it would be so much easier j if you got a model number from it,then we could get a wiring diagram
right i took off the grill and there is no switch under the slam panal... ive had a scout around for the modle number but its a bit dark atm. cheers.
