hey folks was flipping thru an old cop of PVW some of the Show pics there was an audi with a TV screen built into the boot lid would it be possible to mount an amp on the bootlid of me Vento well anythings possible but will the amp suffer any being mounted upside down ? also whats the best way to go about doing this ?
You can mount an amp anyway up you like and it'll be fine. Just be careful where you drill, and make it secure. You don't want it falling off when you slame the boot. Also, it'll make the boot lid heavy, and may not stay open on its own.
no, make sure the fins point upwards or heat won't escape and it'll overheat!!! if you can mount it upside down, it'll tell you in owners manual.
i could be wrong, but if you mounted it upside down then put fans blowing on to it would that work? like one either side of it, one blowing on to the amp and one taking the hot air away, tim
dunno what im gonna do iwant to build a box that =will slide thru into the back seats allowing me to get to my spare wheel which leaves me with a height restriction of 28 cm its all fun lol
fans won't work as the heat usually rises of the circuit where as if it's upside down the heat doesn't escape from the circuit
I doubt there will be much problem with overheating, don't forget the amp will be screwed into the boot lid so that would act like a heat sink too. On a warm summers day that could be a problem though as the amp could be warmed up by the sun through the boot lid. Also the amp would be sitting in the highest (and warmest) place in the boot. Weight is an issue too. My spoiler and sound proofing have made my boot a lot heavier to lift. But it will stay up regardless of the weight as it goes past vertical and leans towards the front of the car. I have mine on the back of the rear seat, hidden behind the sub. Easy to get to aswell, just tilt the seat foreward.
yeah i though t about the seat back but that would mean not being able to slide the box over unless it was raised up on stilts hmm mind boggling stuff
ive got a design of a box which should hopefully solve the problem just need to get some MDF and persuade me dad to dig his tools out if it all comes together i shall try and get pics up of the final solution
