for my 4wd mk2 build, I'm not having a servo and as its got an S3 engine ill be using the drive by wire throttle pedal, so what pedal boxes are available for me (just brake and clutch obviously) or is there a decent brake master cylinder that will work with a mk4 / S3 style brake pedal, clearly the clutch is fine as its built into the pedal, but if i can find a master cylinder to work with the stock mk4 brake pedal i can fabricate the relevant mounts for them. cheers
