Anyone help with a diagram of ecu pin out on 2001 v6 4motion
Discussion in 'Throttle bodies & non-OEM ECUs' started by boab, Nov 1, 2015.
  1. boab Forum Member
    Pm sent
    Sent from my SM-G925F using Tapatalk
  2. boab Forum Member
    If I don't soft code out secondary air injection and rear lambdas and egr would it produce running issues or will it just store codes?
  3. boab Forum Member
    Bump if anyone can help.cant find anyone local who can sort out ecu so thinking of sending ecu away for immobiliser defeat first
  4. boab Forum Member
    Finished off the wiring have a supply at both the Injectors and coils but I've no spark or no injectors opening I know ecu still is immobilised but I would have thought it would have at least started then cut out
  5. MUSHY 16V
    aberdeen
    aye it should start but cut out like you said
    sounds like it's not getting power to the ecu somewhere
  6. boab Forum Member
    Have my feed to ecu through the ecu relay on the red/green earth's on.and ignition supply I'm hopefully going to try connect up with vcds tomorrow see what happens.
  7. boab Forum Member
    OK I've found out with bde drawings aren't corresponding to what live should be there the ecu needs a live on t121/21 no sign of this pin on drawings anyone know why it's not there?I might buzz wires tomorrow see if I can find out colour location of pin t121/21
  8. boab Forum Member
    Another fault found pin3 red/green live supply to ecu terminal has backed out of its holder in the plug it's just missing contact with ecu so hopefully have it connected tomorrow
  9. boab Forum Member
    Running [emoji1]
  10. MUSHY 16V
    aberdeen
    did you get the vag commander to work ?
  11. boab Forum Member
    I haven't tried connecting as yet mate I wanted to get it sparking and fuel as you said it should still start then cut out so now I'm at that stage at least we now have a live ecu it runs and cuts out as it should
  12. MUSHY 16V
    aberdeen
  13. boab Forum Member
    I think ecu going away for immobiliser defeat and soft coding of the rest of things not needed as it's near show time and running out of time to get things done
    MUSHY 16V likes this.
  14. rubjonny
    yes like I said earlier in the thread the BDE wiring diagram has an error and doesnt show the ignition live to pin 21, the R32 BFH wiring diagram does show this feed though and the ECU wiring is 99% the same
  15. boab Forum Member
    I sussed it and ended up working out whoever removed loom pulled the wiring from ecu instead of pulling on the plug the main feed red/green was backed out of its holder in ecu plug just enough that it didn't make contact with ecu.all running now thanks for the assistance much appreciated
    rubjonny likes this.
  16. boab Forum Member
    https://vimeo.com/162175290
    sorted minus the exhaust leak cheers for the help guys much appreciated
