Hi, i have a water leak on my 1992 vr6 coming from the thermo housing area. I've seen the kit on ebay which will replace all the housing inc crack pipe. I contacted the seller who says its all topran stuff. This is the kit.. 220505500573 Any experinces with this kit? Cheers G
I fitted a pipe from same seller to the VR6 race car only last week and fit and quality was fine. HTH, Tim
I bought the very same kit a few years ago for my mk2 vr6. It was indeed TopRan and was made of a very study plastic. The only thing I found was that the crack pipe did take a bit of effort to get it to slot into the ending side, otherwise the rest of the housing was absolutely fine. I also bought some new plastic retainer clips for the sensors too at the same time but the kit itself never failed over 2 years
Here's my comment to another thread about the kit (see post #17) http://www.clubgti.com/showthread.php?222292-110degree-coolant-with-slim-fan-update-Guage-still-not-showing-over-80deg&p=1969232&viewfull=1#post1969232
Bought this kit recently and leaked like a sieve when I re-filled with coolant. Had to go back to the old one, its a job I now need to do again when I can be bothered as I needed the car.
We had same problem initially, but it was because the O ring had come off as we tried to get it in to the water pump! Removed, re-fitted O ring and applied a liberally about of oil to the seal and water pump, after removing any corrosion, and it slipped straight in with no leaks
This is the problem I had with the above kit; I thought I had removed all the crud but the o-ring didn't seat properly and started leaking. But what in fact had happened is the O-ring wasn't in place properly. Once I took my time to make sure every bit of corrosion and crud was free, from memory I found the best way to get the pipe back in without the O-ring coming out of the poisition was to gently rotate the pipe back and forth whilst slotting it in. However I did note that the old crack pipe slotted far easier than the new one even though it never leaked.
Mine leaked like a sieve. Fixed with some Dirko sealant. the faces of the parts aren't even flat! Cheap crap but it will do for now until I get a genuine kit.
