Audi A4 or Passat TDI
Discussion in 'Audi/SEAT/Skoda Chat' started by afbiker02, Sep 23, 2010.
  1. afbiker02
    Bury St. Edmunds
    The wife and I are looking at getting either an A4 estate TDI or a Passat Estate TDI. I' not sure which were going to get but I figured I see what everone has to say and which engine to go for.
  2. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    Both are the same, the finish in the Audi is better
    I'd go with a TDI 130 personally
  3. AndyG
    AndyG Forum Member
    Worcestershire
    if you carry passengers in the back then go for the passat everytime
    the passat uses the Audi A6 shortened floorpan and hence has more interior space than an A4
  4. Gareth83 Forum Junkie
    Wales
    interesting as I will be back in the market for an estate too
  5. Dave
    Sligo, Eire
    Can I throw the Skoda Octavia in there?
    To my mind the choice is between:
    A suberb Audi Gearbox, in the north/south engined A4 or Passat. But the aweful multilink front suspension puts me off.
    Versus:
    The simple strut front suspension of the Skoda. But the transverse box puts me off, compared to the slick almost un-burstable, Audi box.
    Are the brakes the same?
  6. afbiker02
    Bury St. Edmunds
    The wife's not sold on Skoda
  7. AndyG
    AndyG Forum Member
    Worcestershire
    Don't be put off by the multilink suspension, it's not as bad as people make out,
    actually very easy to work on
    I replaced the whole front suspension (all 8 arms) in a couple of hours for my last MOT.
    Not bad though as they had lasted 13 years and 130,000 miles
    Complete kit of arms and tie-rods is under 200 delivered
  8. Gareth83 Forum Junkie
    Wales
    I had a Passat 20V Turbo Sport and that was a nice car, an estate would be just as good, Very roomy as you say.
    What year did they revise the styling? As the older models do look a bit dated
  9. Dan W
    Dan W CGTI Regional Host
    Penryn, Cornwall
    I've personally changed half a dozen Audi gearboxes, not that good IMO, 2nd and 3rd syncro's go as well as diff bearings, only ever had to change one transverse box and that was in a mk4 gti tdi that had had a hard life
  10. Dan W
    Penryn, Cornwall
    Oh and Audi's are a far nicer car to look at and be in
  11. Gareth83 Forum Junkie
    Wales
    are they worth the premium?
    any petrol models to consider for cheap running costs?
  12. DGT
    DGT Forum Member
    The Highlands
    must be easier than the A4 B5/B6 as the 'death bolt' that pinches the upper arms is a complete pain in the ass..
    Loads more room in the passat..The newer passats are horrible inside IMO..too plasticy ..and the residuals are, as usual poor, you can get a 2.0 tdi '56 plate with FSH for 5.5k, the equivalent audi would be twice that
  13. afbiker02
    Bury St. Edmunds
    I haven't really looked at the new passat too much. Also know that if it's got 4 rings the price can double. As for working on them, I'm not too bothered as I have access to a nice shop...
  14. AndyG
    AndyG Forum Member
    Worcestershire
    Passat has the identical setup to the A4/A6, pinch bolt is easy to remove if you know how :thumbup:
  15. DGT
    DGT Forum Member
    The Highlands
    lots of heat..not so handy for your average joe without garage facilities
  16. AndyG
    AndyG Forum Member
    Worcestershire
    I just cut through the length of the bolt, theres a convenient slot for the hacksaw in the upper suspension arm, rotate the head of the bolt a few times, put the steering on full lock to gain easier access and then use a pin punch to drive out the old bolt
  17. DGT
    DGT Forum Member
    The Highlands
    honestly, it must be a different story on A4s, they ALL seize and no amount of hammering or cutting will get it out unless your incredibly fortunate!
    The dealers dont even try to remove it without first heating the area to cherry red, ruining the upper arm bj's,but theyre usually changing them anyway..ive done this twice now.
    Heard of people actually drilling the stuck bolt out, going off centre and having to replace the whole hub carrier, one guy tried to use a stud extractor, which broke in the arm! try drilling that out![xx(]
  18. ivortheengine2 Forum Member
    n.ireland
    Depends what ticks your box , if its space as a priority its a no brainer passat every time , if its just front passenger and hatchback versatility go the a4 , it is more stylish otherwise very similar .
  19. Gareth83 Forum Junkie
    Wales
    which engine aside from the TDI would be cheap to run but not too slow?
  20. AndyG
    AndyG Forum Member
    Worcestershire
    1.8T is more economical than any of the other petrol engines, especially if the ecu is chipped believe it or not
