Can u bolt an audi tt 4wd gearbox into a rallye and use the rallye diff? Weird question I know. Cheers.
Check out www.dutchdub.com if its still up, you need an early TT box with the 20:21 step off Edited by: VR6T
you can bolt in it and use it but you need to use the tt diff too, the rallye diff has a ratios of 21/16, tt or anything that uses haldex is 27/17, vr6 syncro is 21/20 Edited by: nutter4x4
