aum ecu with auq engine
Discussion in '1.8 & 1.8T' started by Ditchyboy, Dec 10, 2012.
  1. Ditchyboy Forum Member
    Shepshed, J23 M1
    hi,
    I have an ecu from an aum (and auq engine) as i was told even though the aum was a 150bhp engine it had a ko3s turbo and therefore was the same as an ecu out of an auq, now i do not know if this is correct. I was told it would map out to 180bhp and then to 210(ish) like an auq would, is this true as if not i need to get a auq ecu?
  2. dsj20v Forum Member
    sunny hampshire
    Iirc they are the interchangeable although diff part numbers, they are both the better me7.5ecu and yes they are same engine just diff oem map so I would imagine with that ecu it indeed would be 180bhp as factory
  3. sparrow Paid Member Paid Member
    Leamington Spa
    They are the same, and a direct swap.
  4. turbotommy Forum Member
    Newcastle upon tyne
    Indeed they are :-)
  5. Ditchyboy Forum Member
    Shepshed, J23 M1
    sweet, cheers for the replies.
  6. george jigsun New Member
    Hi, is it the same situation with ECU 06A 906 032 MJ from AUQ Leon ???
    I mean plug and play on vw golf 2001 1.8t AUM
    Thanks!
  7. Toyotec
    032MJ (180 ps) and 032HJ(150ps) are both plug and play.
    Both can be tuned to the same peak output also.
  8. george jigsun New Member
    Thank you very much!
    cheers
