AVO Coilovers Loose ?????
Discussion in 'Track Prep & Tech' started by trackdaygtimk2, Apr 13, 2016.
  1. trackdaygtimk2 Forum Member
    Hi All
    I have bought a MK2 Golf 16V fitted with AVO coilovers all round, the car has been fully prepped for track days but i am unsure if the front Coilovers are fitted correctly.
    When the front wheels are jacked off the ground the top mounts are really loose and can be shaken and moved by the suspension leg or top mount itself, the springs are all held in tight nut this movement concerns me. The top mounts under the bonnet also appear to be made of a neoprene foam, is any of the normal.
    thanks
    Nick
  2. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Any pictures?
    The top mounts are meant to drop if you jack it off the ground and the top plate stops it falling through the strut tower. The weight of the car is what holds it onto the rubber top mounts.
  3. trackdaygtimk2 Forum Member
    i'll try to get some pictures loaded up later , the top mounts are not rubber they are foam ???? searched all over the internet for foam top mounts for a MK2 GTI and cannot find a thing.
    When i bought the car they were described as 'front floating top mounts' , does that mean anything to anyone ?
  4. fasteddie
    fasteddie Banned
    sounds like mk3 mounts which is normal, mk2 one sit better and have a different top plate to stop the mount dropping as much.
    but in both with shorter coilovers- mounts will float a bit when jacked up.
  5. trackdaygtimk2 Forum Member
    Sorry for the delay in the reply, i have taken some photos but how on earth do you upload them onto here ?
    I have searched everywhere as they look a bit torn but cannot find out what they are or where they came from ?????
  6. Rooster
    Rooster Paid Member Paid Member
    Fleet Hampshire
    Load them onto Photobucket and then post the img link
  7. trackdaygtimk2 Forum Member
    thanks, photo from photobucket below
    [​IMG][/URL]
  8. trackdaygtimk2 Forum Member
    Another picture below , they are looking pretty torn up now as the car has been jacked and the suspension on full droop for the last few weeks whilst i waited for me new brake discs to arrive, when the car was lowered back doen they looked like this.
    Where can i get these new replacements ?????
    [​IMG][/URL]
  9. trackdaygtimk2 Forum Member
  10. MUSHY 16V
    aberdeen
    Aye looks like a attempt to fix a mismatch of parts of some kind that or the are shot
  11. twolitrepinto Forum Member
    Hastings, East Sussex
    Agreed with Mushy, those foam bits are not standard, that top plate looks like its sitting too high, possibly due to worn rubber mounts underneath.
    The foam has been added in an attempt to reduce the movement when jacked up by the looks of it.
    i don't think you are going to know what's really going on without removing the struts and having a good look...
  12. MUSHY 16V
    aberdeen
    aye agreed need to strip it to see what you have
    most people run either g60 top mounts or mk3 ones
  13. trackdaygtimk2 Forum Member
  14. trackdaygtimk2 Forum Member
    Forgot to add , part number on the top metal stop plate is BLH 191412411 ???
  15. MUSHY 16V
    aberdeen
    Me or rj will have a look tomorrow at the part number
    A lot of home made stuff going on there [:s]
  16. trackdaygtimk2 Forum Member
    Thanks gents, I have searched every car on parts base.org and cannot find any reference to that part number , it is stamped with the vw and audi logo so is genuine , this car is becoming more of a mystery the more I delve !!!
  17. trackdaygtimk2 Forum Member
    Any joy finding the part number ???
