Bearing puller?
Discussion in 'Tools, Equipment & Fasteners' started by thegave, Nov 11, 2008.
  1. thegave Forum Member
    London
    I'd like to swap my steering wheel for a small spline GTi wheel so apparently I need a bearing puller to remove the existing large spline adapter.
    Um, is there anything else I could use to improvise or is there anyone in the Central London area who could lend me one? Har. Don't really want to buy a tool I'm only going to use once...
    ta
  2. StuMc
    50? 20` 47 N - 06? 57` 57 E
    You can get a decent small puller kit from Halfords.
    Not very expensive, and they are handy to have. Even if you think you only need them once, there`s bound to be another job they`ll come in handy for...
  3. rubjonny
    if you give end o column a good smack with a hammer that can get it off, thread the nut back on to protect the thread and use a bit o wood to sofen the blow.
  4. thegave Forum Member
    London
    Does that just wriggle the spline adapter loose?
  5. rubjonny
    what happens is the inner column collapses a bit and the adaptor pops off, then all you do is refit the wheel & nut loosely and give it a good yank to re-extend the column :)
  6. thegave Forum Member
    London
    So I tap the side of the column near the top? Or straight on the point like a nail to knock it inwards?
  7. rubjonny
    tap it stright on as if you were hammering the column like a nail :lol:
  8. stevesellars Forum Member
    Blackpool
    so i should need a puller then
  9. rubjonny
    ideally yeah a good puller, but even then it sometimes doesnt work.
  10. nodeward Forum Member
    get a puller dont even bother trying to knock it off with a hammer you will end up doing more harm than good, take it from someone who knows!!!
  11. chrisbex123 Forum Member
    glewstone ross-on-wye
    My mates dad used an air chisel on either side at 3 and 9 o clock and it pinged off a good un, nearly took the caddy back window out mind. mullers the adaptor piece but its not needed anyway. aim from the pedalbox area. its awkward but does the job in seconds. any good garage should do it for naff all.:thumbup:
  12. stevesellars Forum Member
    Blackpool
    so if i undo the uv joint so its just handing loss, if i was to put some wood over the end on the adaptor and hit it with the hammer would the adaptor pop off?
  13. rubjonny
    with the hammer approach, what will happen is the column will collapse, while the outer column stays extended. this will pop the adaptor right off, unless its proper welded solid in place.
    you refit the wheel nut loosely to protect the column threads then put the wood on the end of the column, not the adaptor.
  14. stevesellars Forum Member
    Blackpool
    got it sorted cheers rubjonny
  15. rubjonny
    nothing quite so satisfying as sorting a problem with a hammer eh :lol:
  16. coupechamp Forum Member
    Northampton
    aaarrhhhh, it's that old saying..........if in doubt.....give it a clout:thumbup:
  17. stevesellars Forum Member
    Blackpool
    Cheers gang
  18. dutchboy
    dutchboy Paid Member Paid Member
    Blackpool
    I'm struggling with this at the moment!! So does the hammer thing work then? I don't want to damage my steering column! Ta
  19. Mike_H Forum Addict
    Yes, but put the nut back on the end threads of the column, and use a piece of wood to protect it. Done it myself in the past. A squirt of releasing fluid might help as well.
  20. dutchboy
    Blackpool
    Well I have succeeded with the "hammer treatment" quite easy really.
    My next question though: I want to use my small splined steering wheel but since I took the spline adapter off, the spring is no longer compressed when I put my small spline steering wheel on? What am missing?
    Cheers
